amp gain and sub compatible?
ok, sounds no different to me please research it for me?
---------- Post added at 01:39 AM ---------- Previous post was at 01:38 AM ----------
also research what 'normal gain V' is please as i want it @ 2V stock original normal max head unit
That wont be found anywhere ..if u want it closer ur gona have to use a oscope or dmm..and what setting is this -6-12 under? If it doesnt make a diff it might not pertain to the woofer
Its just where u want to the subwoofer crossover set ..im not sure what the other -6-12 is for .or what setting its under ..play with it and see what sounds best
Has me alil lost aswell.there should LOW,MID,HIGH,which goes -6 to +6 on all three.then sw controls from-24 to +6.sla 0 to 4
You need to read more rather then ask questions. You should also read the manual of the radio. You are asking about totally different things. Crossovers and slopes vs gain settings. Just read, all of your answers are in the amp manual and the radio manual.
pioneer_stan
pioneer_stan
Australia
pioneer_stan
