Amp fuses keep blowing
blitz_fist
My amp was running well all day yesterday, no problems. Last night we had rain, and there's a little hole in my trunk where the taillight is, so the ground terminal got wet, because it was grounded right under the hole, and after around 30min of strong playing, the fuse blew. So I get home, relocate the ground to the seat belt nut, put in a new fuse, and caulk up the hole. Everything is dandy, it plays for like a minute, then the fuse goes again! I thought I dried the terminal off, but maybe I didn't all the way. Also, I had to cut the o ring connector for it to fit on the bolt because it was too big, could that have something to do with it?
Could a bad connection be the cause? The battery wire is kind of just stripped and shoved into the hole, and screwed down.
Also, the amp is attached to the box, which moves around a lot when I drive, so I know the wire is being tugged on roughly, because it doesn't have much slack at all.
I'm going to put some spade terminals on the wires tomorrow and secure it to the floor of my trunk, or mount the amp on my backseat.
So today I mounted the amp on the backseat, checked all along the wires, put on proper terminals to connect to the amp, but it's still blowing fuses.
It also does just fine until I turn it up loud, with the bass up, then it blows the fuse. Just keeping it at a low volume it keeps going just fine.
It seems pretty tight, but it might not be flush with both sides of metal because of the angle of the metal. The amp didn't get and water on it at all, just the end of the ground where I had it connected to the chassis.
blitz_fist
blitz_fist
Sarasota, FL
blitz_fist
BP1Fanatic
BP1Fanatic
