Amp fuses keep blowing
make sure ground is as good as you can get if possible use a bolt and nut on the other side to keep vibrations from loosing it but i could be barking and blowin your fuse ... fuse in amp right or power wire??
Yeah, it feels really hot when I'm done, like it burns my hand. I had it mounted on my box when it blew the first time, today I put it on the backseat and I have the same results.
Tommorrow go over your power wire redo it at battery if you have a doubt in your mind try using an ring terminal if you can just try to get the safest best connection possible then run down the power wire make sure no bare wire showing check remote make sure nothin is bare and a good connection check ground move to different place make sure try make you remove the paint or gloss from the metal if any is there an in-line fuse in your setup??
blitz_fist
blitz_fist
Sarasota, FL
blitz_fist
