amp for sx15???
You should be giving it plenty of power, unless your amp is way overrated....maybe try box placement, or build a new box? What more do you want out if, more spl or what?
more thump type sound... i guess low end is what i want... but i want to run it at it's full potential is all... just so i know for sure that i'm getting the most out of it
my amp was benched at 11-1200rms on avg, think elec upgrades'll help insure that i'm getting the most out of my setup?
Are you getting dimming or voltage drop now? You should do the big three for sure, it cant hurt.....What is your box currently tuned to?
Ive always heard that the SX is an improved HC, and my 12" HC got looowwwww tuned to around 31......so Id bet the SX has quite a bit low end potential
35htz, i want it at 30 but i don't wanna rip my box apart
You MIGHT be able to alter your current box, but then again it might be easier to just build a new box, and see which one you like better. Before that, you might want to play around with your box placement some, see if it helps anything.
by box placement you mean aim the sub different ways?
Yeah. That and move the box around in the blazer, sometimes it can make a nice improvement. To get the monster low end it sounds like you want, you might have to change/replace the box though. Maybe someone around you has a similiar box tuned a bit lower you can try?
psych0ticnemes1
Psych0tic Customs
psych0ticnemes1
Behind You
psych0ticnemes1
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
