frankiebones 10+ year member
i have never heard of 3 ohm impedence. what kind of amp do i need to look for. i currently have a kicker kx400.1 mono, here are the specs for it:
Number of Channels 1 - Mono
RMS Power (4 ohms) 200 watts x 1 chan.
RMS Power (2 ohms) 400 watts x 1 chan.
Peak Power Output 800 watts
Min. Impedance Unbridged 2 ohms
Min. Impedance Bridged Not Bridgeable
THD @ Rated RMS Power 1.5%
Speaker Level Inputs Yes
Amp Preamp Outputs Yes - 1 Pair
Built-in Crossover HPF/LPF (50 - 200 Hz)
Frequency Response: 20Hz-200Hz; +0, -1dB
Input Sensitivity: High Level 340mV-10V, Low Level 170mV-5V
Signal-to-Noise Ratio 95 dB
Bass Boost 0 - 18 dB
Fuse Rating 40A
what wattage will it put out at 3 ohm, if it is capable of running at 3 ohms. can it be wired to a 10W7? thanks.
Fuse Rating 40A
