Amp for 4 re8's?
Hey,im looking at getting 4 re8's that are single voice coil and 4 ohm.I was wondering what a good amp would be to power them.Also how exactly should i wire them? Trav
this might help with the wiring, and is the only way i know of unless you seperate them and run 2 sets of 2? as far as power goes..........what kind of car,box,speaker handling,and output are you looking for? i might have what you need?
4 SVC drivers with Voice Coils in Parallel
All woofer (+) to the amp (+). All woofer (-) to the amp (-) connections.
2 Ohm Subwoofers: 0.5 Ohms
3 Ohm Subwoofers: 0.75 Ohms
4 Ohm Subwoofers: 1 Ohm
8 Ohm Subwoofers: 2 Ohms
12 Ohm Subwoofers: 3 Ohms
i couldn't get the da$m pic to paste but hope you get the idea?//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
Hey,thanks for the info.So let me get this straight i will be running all 4 for a total of a 1 ohm load? I will be putting these in a jeep wrangler in a sealed box (i think they will fit)and am just looking to get a different setup than my 2 12" kappa perfects i have had for 4 years.Trav
I have two 12'' Kappa Perfects for sale on soundsolutionsaudio.com/forum. I think you should get those and run 4-12's......what do ya think?//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If the older RE8's are 175w you're looking at 700-800w at 1 ohm, but you're going to have a lot more options at 1000w so I'd just go that route and set the gain accordingly.
You can find a Hifonics bxi1206d or a Lanzar Opti 1400D for around $200, or you could step up to the Audioque AQ1200D for $250. There are plenty of options -- your budget has a lot to do with it.
Your wiring would look like this --
FWIW - you could also wire them for 4 ohms and go with a large 2 ch amp that will give you ~800w bridged.
Wiring for that...
My old RE8's... the ones with the non-chrome motor (they are like a nickel plated metal)... are single TWO ohm...
The newer ones with the chrome motor were usually DUAL 4 ohm...
Check yours... this will dictate the amplifier you need.
I'd recommend anywhere from 600rms-1000rms depending on box type and application. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I was jamming out on mine today... 4 8's ported with ~450rms... tons of fun...
nG
Wow, that a'tek is a clean looking amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It's class a/b though, so not quite as efficient as a similar power class D
Travman
Travman
Alpena,MI
Travman
Mike Mccabe
