Amp for 2 12 kicker comps
fartcan
I have two twelve inch 2003 kicker comps in a sealed box. Right now I'm powering them off a 125x2rms sony xplod amp. The comps are rated at 150 watts rms.
Do you think I should upgrade? Are profile and MA Audio amps any good? What type of amp should I get(around $125).
First off, what ohm rating are the subs? If I am not mistaken, the Kicker comps are SVC, correct? We need that info to make sure you get the correct amp. I dont think that sony amp is putting out what it says it does, so a new amp would definitely help imo. Post that info and I will check back and make some suggestions.
Not sure about the distortion. The following link shows your two options for wiring them.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=1
A third option is a 2 channel amp, run them strait in at a 4 ohm load per channel. What I would do is get a Kicker ZX300.1 mono amp. The Kickers are slightly under-rated, and you would just use option #1 in that link. A refurb is cheaper, fits your budget, and a new one isnt much more. Here is a link:
http://cgi.ebay.com/KICKER-ZX300-1-CAR-AUDIO-300-WATT-CLASS-D-AMP-AMPLIFIER_W0QQitemZ130208702634QQihZ003QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Second option would be a Kicker ZX350.2, but it is a little more expensive.
http://cgi.ebay.com/NEW-KICKER-ZX350-2-350-WATT-2-CH-AMP-REPL-KX350-2_W0QQitemZ180228380337QQihZ008QQcategoryZ39732QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Either should power those subs well, and either would be much better than the sony, profile, or MA amps.
fartcan
fartcan
South Dakota
ARK_SWAMP_RIDER
