murzar
I have a Toyota Prius and a Memphis 1000D. How would I connect the positive wire to this battery? That block is a voltage regular maintaing 14.1v and there is a 120v fuse on it.
Also is the stock ground wire ok or should I sand it down, replace with a larger guage, etc? This is a JIS standard battery with the positive post being 14.7mm wide and the negitive is 13mm wide, 325 CCA and 71 RC.
