Amp and Subs Compatability?
I have an amp and two 10"DVC subs and want to change from a stereo hook-up to a bridged/mono hook-up. Currently the v.c. is wired series on each sub and each sub is on its own channel. I've been told I should wire the subs series and parallel both and hook up mono. My problem is I don't know if the amp and subs are compatable this way. Here are the specs on both the amp and subs. Could someone point me in the right direction? I don't wanna blow anything up. Thanks.
Audiobahn A3201T
1680W Max, Class A/B 2-Channel Car Amplifier
RMS Power Rating:
300 watts x 2 chan. @ 4 ohms
420 watts x 2 chan. @ 2 ohms
840 watts x 1 chan. @ 4 ohms Bridged
Max Power Output: 1680 watts @ 2 ohms stereo or 4 ohms bridged
Infinity Kappa Perfect 10.1D
•10" subwoofer with dual 4-ohm voice coils
•aluminum cone with high-roll butyl-rubber surround
•massive cast-aluminum basket
•suitable for free-air use (handles up to 175 watts in free-air applications)
•power range: 75-350 watts RMS (175 watts per coil)
•peak power handling: 1,400 watts
•frequency response: 18-200 Hz
Wire the subs like this:
and bridge the amp...
Shawn T
Shawn T
Little Elm, Texas
misfit138
NorthFramingham
    Jun 30, 2026
