amp and sub install
  • 2
kuda
Guys
I need a little advice
I have a 2008 maxima im doing a modest system in
Factory Bose speakers
Pioneer 4400 head unit
Single Diamond d6 12"
And Im looking at an amp
Jl 1400d to power it
What do ya think...will this amp run the sub properly?
And also...the box the sub is in *****
So Im looking to build another ported box for it
I dont wanna take up alotta trunk space tho
Any thoughts and input would be awesome!
Thanks guys
If you're buying it new, there are a zillion other amps out there that are as good or better than JL for less money. Matter of fact, even if you're buying used there are still comparable amps that are likely to be less expensive new.
As for the box, there is a range of volumes from smallest to largest that your sub will perform well in. If the smallest is too large, don't build a ported enclosure because it'll sound worse than sealed.
That's a good price for the amp.
As for dimensions, if those you gave are external, that's .95 cubes before any displacement and if they're internal, it's 1.38. Again, before displacements. So if that's all you can give up you'd be better off going sealed, imo.
I can give up more room
Im an older guy
Im not looking to blow my head off
But I like it to knock
I really like good Clean sound
I can probably do 24x12 12
Better?
Again...the amp in question jl e1400 d
Enough to power the single.d6?
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
459
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
615
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
623
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
kuda
kuda
United States
kuda
    May 12, 2024
Brendon Jenness
    May 11, 2024
