amp and sub install
Guys
I need a little advice
I have a 2008 maxima im doing a modest system in
Factory Bose speakers
Pioneer 4400 head unit
Single Diamond d6 12"
And Im looking at an amp
Jl 1400d to power it
What do ya think...will this amp run the sub properly?
And also...the box the sub is in *****
So Im looking to build another ported box for it
I dont wanna take up alotta trunk space tho
Any thoughts and input would be awesome!
Thanks guys
If you're buying it new, there are a zillion other amps out there that are as good or better than JL for less money. Matter of fact, even if you're buying used there are still comparable amps that are likely to be less expensive new.
As for the box, there is a range of volumes from smallest to largest that your sub will perform well in. If the smallest is too large, don't build a ported enclosure because it'll sound worse than sealed.
That's a good price for the amp.
As for dimensions, if those you gave are external, that's .95 cubes before any displacement and if they're internal, it's 1.38. Again, before displacements. So if that's all you can give up you'd be better off going sealed, imo.
I can give up more room
Im an older guy
Im not looking to blow my head off
But I like it to knock
I really like good Clean sound
I can probably do 24x12 12
Better?
Again...the amp in question jl e1400 d
Enough to power the single.d6?
kuda
kuda
United States
kuda
