amp and sub in and out
i have them bridged because this amp has a mom setting and a stereo setting(which is 2 channel mode) i get more power and more bass out of the mono setting
ok you have 2 single 4omh subs. the only way thoes subs both together wire to is 2 ohm or 8 ohm.
you said you had bridged your amp. lookin it up , your amp is only stable to 4 ohm mono. your amp is not stable at 2 ohm mono. which could be where your subs are wired too.
so you have the subs wired wrong. which i could be causing your problem.
how should i wire them like a 2 channel i also asked another source they said try turning down the gains but i dont have gains on my amp the levers on my amp are bass boost level (db), lpf frequency, hpf frequency, and input sensitivity
BrokenSilence1
BrokenSilence1
MD
BrokenSilence1
