Amp & Sub install problem, need help
Cadman27
I installed my eclipse amp with 2 12" pioneer IMPP's and all I did was just hook up the power, the ground, and the remote wires. And now my passenger side taillight keeps blowing and i have no reason why. So I just disconnected the ground and power wire so my fuse quits blowing. I have a 40amp fuse on my power wire right now. Should I use a bigger fuse on my power wire, if so what size fuse? Any help would be appreciated, Thanks!
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
i have a Mitsubishi Lancer 02' and it has separate fuses for each taillight and my right taillight fuse keeps blowing, nothing else just that one fuse, everything else is fine.
check to make sure you didn't pull any wires loose from the plug at the taillight. also check any grounds in the area for loose bolts and such. I had the same problem in my old car, turns out when I did my install for my amp rack I put to much stress on the light plug and shorted it out just enough to blow fuses.
Good luck
Cadman27
Cadman27
Turlock, CA.
southwest713
BP1Fanatic
BP1Fanatic
