Amp & Sub 10'
avw241
Looking for a good amp to run 4 10' sub's. Also I want to know who has the best 10' subs. Thinking about getting the Alpine 10'?
93 GMC Suburban
Head Unit - Alpine 7998
Front Dash - Infinity Kappa 462.3cfp
Front Door Custom - Infinity Kappa 60.3cs
Rear Doors - Infinity Kappa 63.3i
Custom Rear Doors - Infinity Tweeters 10.3t
Rear Celling - Kenwood KFC-415
Sub's - 4 Dept Chart 10'
Rear Doors Celling - Infinity Tweeters 10.2t
Front Amp - Alpine MRV-540
Rear Amp - Alpine MRV-540
Sub Amp - Rockford Fosgate Punch 500.2
Originally posted by avw241 Looking for a good amp to run 4 10' sub's. Also I want to know who has the best 10' subs. Thinking about getting the Alpine 10'?
10 ft SUBS???!!! WOW! 4 of them??!!!
just kidding. Well if your other amps are alpine, then stick to alpine. Unless you dont like them for some reason.
yea he's right.. if you have alpines amps why not stick with them.. but if you dont want too i have a MA Audio amp M1286i. it's rated 1200x1@1ohm . send me a PM if interested
Well.. this depends on what you are looking for.. If you want it the loudest possible, i would say the 4 10's.. alot of cone area.. But, if your looking for more SQ, then the 2 12's should sound better. I would go with the 10's..
Originally posted by badazzDD Well.. this depends on what you are looking for.. If you want it the loudest possible, i would say the 4 10's.. alot of cone area.. But, if your looking for more SQ, then the 2 12's should sound better. I would go with the 10's..
Me too //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
March 10th is when the presale ends and they say shortly after that.
I'd assume by april
Product Specifications - Rated at 11v
So its rated at 11v...what about at 14.4
Correct me if im wrong, but this is just an estimate...
Amperage x Voltage = Wattage Watt / Volt = Amp
1200 / 11 = 109.0909amp
SO,
109.0909 amp x 14.4 volt = 1570.9089watts
avw241
avw241
Maryland
t1990le
