American bass 1100.1
cal
a.b vfl 1100.1 12 v version
1 ohm Stable Class D Mono Block Amplifier
Low Level Input and Output
Frequency Response: 20Hz ~ 350Hz
Input Level: 0.2V ~ 6V
Variable Subsonic: 10Hz ~ 50Hz
Variable Low Pass Filter: 35Hz ~ 250Hz
Variable Bass Boost: 0~ 9dB at 45Hz
Remote Gain Controller
Two amplifier Linkable Connector and Controller
12,500 Watts RMS
Width: 9.5"
Height: 2.25"
Length: 36"
amp is used but clean and fully working , the amp was repaired by previous owner due to water causing fets to blow . from what i was told all fets on power supply side were replaced to match and gate resistors were replaced as needed . i tested the amp and its fulling working i also had a shop bench test the amp and they confirmed amp has been repaired to factory specs and @ the time of inspection needed a new fan and that has been replaced as well. the only reason im selling work is slow and build is slower lol.
1450 shipped con u.s. 1350 picked up
no trades
cal
cal
Jayzbent
