alternator wiring
idk bout you but i only did 1 wire....batt + to alt+ alternator is bolted to engine block and there is ground from engine block to battery on my car...so and ran no fuse as i know where my wire is and its secured away from moving parts and sources of extreme heat.
Great way to have a rolling fire hazard! Why don't you install a mobile meth lab while you are at it:laugh:
Didn't you also use the wire harness part of the alt?
no there was no need to on my car...1 wire only.
and as for the rolling fire hazard comment..i've never had a wire burn....or even become hot....so why would it be a fire hazard...please do explain that one.
a wire always can get broken (example: acident) and if anywhere in the + wire gets contact to ground it gonna burn al the lengt to the batt
taintedplay
taintedplay
dallas
SicAudio
