Alternator Whining
Hi everybody, I know that i have alternator whining because when i turn on the engine, my speakers start to whine and when i rev my engine or use any of the electronics in my car, the speakers will make noises or get louder. I'm pretty sure i've narrowed it down to the RCA's grounding out somewhere, but i have no idea whether it's on the 4 channel 800W amp im using or if its the Alpine CDA-9856 HU im using. I've seen simple fixes like grounding each RCA cable on the HU but that doesn't seem to work for me. Does that mean it would be a problem with the amp? Either way does anyone know a fix that wont weaken my speaker quality?
Could be an issue with that amp, or a bad ground all together.May try a different ground location for the amp to see if that may be the issue first
I moved the original ground i had on it to the wingnut on the spare tire, just like i did with the amp for the subs. Originally there was just a buzzing on the 4 channel amp but once i moved the ground, it became that higher pitched whining.
Have you tried another set of rcas yet??Can run across the seats just to test?To see if it may be the rcas,..Could be the amp though
well i dont have any extra rca's on me i dont think. I'll have to go pick some up. I'm still just not sure if its the amp though. The speaker's wouldn't work if the amp was bad right? hell idk this is all still pretty new to me.
Hey bro,
I'm having the same issues, before you buy anything try the following, it will help you isolate the issues and post back with the results.
1. Disconnect both sets of RCAs from the 4 channel amp then turn on the car, is there any whine?
2. Reconnect the front speaker RCAs, leave the other set you already disconnected unplugged. Start the vehicle, any noise?
3. Disconnect the front RCAs and then reconnect the other set and start the vehicle, any noise?
Post back with the results, also what kind of vehicle are we talking about? Is this a new install? Did you use the ground on the harness for the head unit? Or did you run a dedicated ground for it?
Let us know! Do this before you spend any money buying anything, all of your equipment is *probably* fine.
Ok so i have two sides of RCA's. One is black and one is white. (Black goes to red, White goes to white). When i unplug the whites on both sides there is still whine. When i put the white back in and unplug the black on both sides, there is still whine. When i unplug both completely from either the HU or the 4 channel amp the whine will go away, but the speakers will not do anything.
This is on a 1999 Mitsubishi Eclipse. I installed this amp maybe two weeks ago? It originally had more of a buzzing noise but then i moved the ground to the wingnut on the spare tire so it would be a better ground. Now i have the whine.
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
964
I don't have one...but I check my voltage with a dmm once a week or so
914
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
What the ****? Are you trying to put ohm's law into very complicated verbiage?
InfinityBeats
Phoenix, AZ
maylar
    May 20, 2024
    May 20, 2024
