Alternator Upgrade
  • 1
timma100
So i'm looking to go louder, current setup is a Zv.4 15" on a BC2000D @ .5Ohm. The first thing I need to do is upgrade my alternator. I've done the big three, have parallel runs of KNU 0 Gauge to a group 24 AGM in the trunk. I've gone into the ECU and bumped up my idle RPM as high as it can go (1K) But still I can't be at full tilt with the fan on lol.. So, should I save my pennies for a DC Power XP270? Or statch something from ebay for half the price? Mechmann requires a smaller belt thanks to its undersized pulley and only makes power high up in the RPM range. The combination of needing a smaller drive pulley to increase alternator speed, and the limited high end output are negatives in my opinion. The DC Power alternative uses a stock size pulley so no need for a special belt..
Looking for opinions and suggestions to start producing good power for the system (that will inevitably lead to a larger amp, NSv.3, and who knows what else)
No not needed. The difference in gain on the amplifier would not draw more power from the battery. Still yet efficient. The gain in volts is a...
This is really the only correct answer since we have no way to account for the other variables. If you're not talking about the same exact...
Also, the alt is grounded to battery and cab. You can see the cables at the rear left mounting bolt.
20
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
timma100
timma100
Barksdale AFB
timma100
    May 31, 2024
    May 24, 2024
