Alternator power?
  • 4
chickenhunter
19
NYC
im dropping in a decent sound system in my old 1968 plymouth fury but to power it all i figured i needed about a 90 amp alternator (i think it has about 30 amps now). so i went down to the local auto parts place and asked for one and they said the highest i could get for my engine (straight 6) was 60 amps. anyone know if this is true? if so will 60 amps be enough? can i keep my old alternator in too and run both? if not, where could i get an alternator good enough?
thanks
The 60 should be fine. If you get a second battery that is. If you wire the amps to your one battery it could drain it and the alt wouldn't charge it.
I think 60 is good for your app, but like I said a second battery wouldn't hurt.
I'm not sure, but the guy might be sayin that b/c orig. factory specs call for the bigges alternator being 60 amps. How do ya think guys w/ CRX's (for ex.) hook up high output 200+ amp alternators in them to power their systems. Factory max (again for ex.) prob calls for no bigger than a 90 amp alt., depending on power options. A '68 plymouth wouldn't have high drain options like an A/C or whatever, thus the smaller alt. Possibly it is the size as well, but that is prob unlikely. Those cars are pretty **** big... plenty of room for expansion.
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
847
I don't have one...but I check my voltage with a dmm once a week or so
12
873
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
What the ****? Are you trying to put ohm's law into very complicated verbiage?
6
chickenhunter
chickenhunter
NYC
audiolife
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
