alternator help
You're not guaranteed more batteries will suffice, but they will help. It also depends on what you plan on running on the amp and at what ohm. If You ran the amp at its full potential, that's about 330 amperes @ 14 volts. If you listen to long bass notes at loud volumes, no number of batteries will work for you because your stock alt wouldn't be able to keep them charged.
Just get 2 big batteries for the trunk and you'll be fine.Couple of d3400's or kinetik's maybe a yellow top they will cost about the same as an alt maybe a little less.And its a lot less hassle;)
i think putting in a new alternator is alot less hassle than wiring batteries in the back. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused://content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
If you say so:rolleyes:Lets see removing a greasy old alt that may be in some crazy precurious location that requires a third arm.Then re-installing the new alt.Then hope you have good voltage at idle.Or buy 2 batteries,install/place them in a nice clean trunk,parrell the batteries and your done.
To me that sounds alot easier.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
x2
call matt at mechman 1888 632-4626 they might have an alt for u. however your car is pretty new, just like mine......... matt still hooked me up ; ) just had to do a little extra work on my part.(first 06 civic alt he made) almost done though lol. they usually have a drop in version for almost any car, mine was sort of the prototype for the new gen civics....
AHSinfonia1898
AHSinfonia1898
Rock Hill, SC
UNDERGROUND_BUM
michigan born
    May 14, 2026
michigan born
    May 14, 2026
