alternative to terminal cups?
  • 5
osmith
kentucky
I know that I've seen some people run bolts through the box. Just wondering what the best way to do that is? Or if anyone has any other alternatives aside from just drilling a hole in the box and running the wires through it.
Bolts + mechanical lugs
Mechanical lugs look like this:
I found some at Menards in the electrical section for pretty cheap.
i just bolts......attach the wire coming from the sub to ring terminals put the head side of the bolt on the inside of the box and drill threw (pre drill holes smaller then bolt)
then on the outside of the box attach a washer to the bolt then attatch ur speaker wire to ring terms coming from the amp
attach to the bolt and either use a nut or wing nut and tighten down from the outside
Then if you need to remove the wire from the enclosure for some reason it's a PITA. I have mine setup like that right now and had a lot of problems with the ring terminals pulling out and everytime that happened it was just awful trying to fix it, the mechanical lugs eliminate that and essentially install heavy duty terminals on the box.
i get what ur saying ya it is but i wouldnt kno how to do the mechanical lugs....any help?
put a bolt threw it? and connect with rings on the other side?
No ring terminal needed. You put the bolt through the hole in on the back part. The front part is exactly like an amp terminal with a set screw. So you just strip your wire, insert, tighten set screw, ???, PROFIT!!!
There are all kinds of Ideas out there by a search on the internet these days. Find the one that works for your situation and budget and...
Hey there I've had this Axxera AV7336MB for years now, but it's got some issues and needs to be replaced. I went to go buy a new one, only to...
Have you browsed the Audio Control DSPs, like the DM608?
I love my m25 tweeters and will likely try the tm65mkiv or tm8 next.
osmith
osmith
kentucky
justafifteen
    May 16, 2024
    May 16, 2024
