JoseMCeee
$tack
Right now I have Both 4 gauge grounds from the 2 amps to 1 1/0 gauge direct connect ground block. My question is, is this what is causing this whine? That the grounds are twisted together? Also, this is on the sheet metal not the actual body and a ground to the actualy body would be too far. Would puttin a bolt thru the bottom and tighten the grounds with a nut get rid of this?
