Alpine type r dual 4 ohm vs Alpine type r dual 2 ohm
dangerranger
The Danger Ranger
ok i am wondering, i am not the brightest crayola in the box with ohms and everything ... but i was jus wondering what is the difference ... i mean i go to look at amps and it shows taht at 2 ohms they can run at higher watts .. so whats that mean ... i am just unsure which to go with ... I mean if i go with a 4 ohm other than a 2 ohm what difference does it make? thanks a lot
wait so it says 4 ohms ... runs at 500 watts x 1 chan ... doenst that mean that it would only give each sub 250 watts ... but if i only have one and run it on the 2 ohm wouldnt it push 1000 watts rms to one sub ... man this is kinda confusing
get the dual 2 version.
this way you can run it as 1 ohm or 4 ohms. i say run it at 1 ohm and watch the gains.
IMO in single dual 4's you have lack of flexibility.
so if i did something like that would i be over powering my subs? because if the dual 2 is hooked up to be like a 1 ohm then it would be running at 1500 watts rms ... shouldnt i do something more like
then if i do that ... it would be ran at a perfect 500 watts rms ? i just dont want to over power my sub but at the same time get what i want out of it
for number 1, just watch your gains. set it using the tutorial stickied on this forum. its okay to have a 5kw amp running a 1kw sub, just be extremely careful how you set your gains.
erm for number 2, hifonics really isnt notorius for putting out its rated power, so yu will be underpowering that sub at 4 ohms
dangerranger
The Danger Ranger
dangerranger
Bakersfield, California
SBLAZER
