Alpine Power Pack using factory wiring?
  • 3
johnckhall
CarAudio.com Newbie
Newbie here and I plan to replace everything in my 1999 GMC Sierra Ext Cab. I'm going with the following: Alpine CDE-172BT Head Unit , Alpine KTP-445A Power Pack, Infinity Reference 6.5" component front , Infinity Reference 4x6 rear
My questions are: Is the original speaker wiring OK to go with? It seems like a pretty easy install if so.
Is it worth it to go through the pain to replace the factory wiring if the Alpine Power pack is only producing 45W per channel?
Lastly, if I did replace the wire with new speaker wire, where would I spice into the Power Pack's harness?
Thanks a lot!
John Hall
I have their powerpack in my Explorer, and I like it, but I did add it the same time I replaced my deck (alpine cde-w265bt), so i can't compare it with the deck outputs. I would go ahead and do it, so you only have to tear apart your dash once. I have owned enough alpine amps that i have faith in them. I assume Alpine does a lot more research and experiments than we ever could before they release a product. I did not run new wire for speakers, and I haven't noticed any problems. Obviously thicker wire means less resistance, which is beneficial for any conductor, but to me it isn't worth the hassle and kind of nullifies the convenience of using an inline amp.
If i had one complaint, it's that higher output means each "click" on your volume knob creates a greater difference in volume, but that goes for every amp. If you prefer loud music out of your speakers, that's a perk; if you search for a perfect volume, it might be an annoyance.
- Joe
To your last question: If you decide to run new wire, splice to the output of the powerpack. Your deck plugs into one side, and the other side is the output.
- Joe
Thanks for the advice, Joe. I'm going to leave the factory speaker wire mainly for your reason alone (that I thought about already), it defeats the purpose of the convenience of the unit to run entirely new wire. I'm not sure what gauge speaker wire came from the factory, but I think it should be OK with this set up. Unless someone has a different take on it ???????
I am going to install my Kenwood KMM-X705 Excelon head unit and a set of Infiniti Reference 6.5 mids and tweets in the front. I have a pair of...
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
103
This weekend I will be taking actual pictures for other sites. So grab it before its gone
6
531
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
johnckhall
CarAudio.com Newbie
johnckhall
Brunswick, Georgia
johnckhall
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
