Didn't feel like starting multiple threads so here it goes, any feedback appreciated.
Wiring: I have a 93 toyota camry LE. Currently I have an optima yellowtop and zero gauge positive and ground from it going to the trunk. I also have zero gauge grounding the battery to the frame, back from when I used to ground my amplifiers to the chasis.
1. Can I just add another battery in the trunk without adding an extra ground, seeing as the battery under the hood is grounded to chasis with zero gauge?
2. When I fuse both ends of the positive wire running from the one battery under the hood to the other in the trunk, do I use the fuse rating of the alternator (around 60-90 amps, not sure what stock toyota alt is). Or do I fuse based on the max current draw of the cars starter (again, no idea), dont plan on using a battery isolator. Or do I use the combined fuse rating of all my amplifiers, 450amps (three MTX amplifiers at 150amps each).
3. My two subs are rated at 900watt RMS, and I have infinity referency component speakers front and back. Do I really need an alternator upgrade if I don't crank my stereo that often, that loud? I plan on getting a new car in a couple years, this is my final install for now...I figure most of the time I drive the car, the stock alternator can keep the batteries topped off for that seldom 20 minutes a day I drive home from work, pissed off at 3am cranking it.
Porting: My new box is about 1.75 cubes per sub after displacement ported to 25Hz. Its for a couple 10" audiobahn flame Q's, until I buy some 10" FI Q subs.
1. Whats the lowest you can port a box? Is it bad to port under Fs?
2. When a woofer manufacturer states a frequency response, say 33-900 Hz, how is this achieved? Is there a low frequency cut off inherent to the woofers design, or is it in conjunction with the box design? For instance if you had an 8" woofer with a frequency response given down to 33hz, could you tune the ported box lower than this and expect bass below their cuttoff point? Or is the woofer itself going to roll off sharply despite the box? My main curiosity is do you need larger woofers for low end extension. Besides higher sensitivity, lower Fs, more excursion, ect, can you still use small woofers and tune their box to extend as low as the big boys?
3. Alot of people on this forum talk about high SPL numbers. Who amoung the SQ crowd has tuned extremely low or has designed subs that dont drop off until 20Hz? Is the ideal sub design totally flat down to 20hz (For listening purposes), or do you prefer a roll off that sums with cabin gain for a net flat-line?
Alot of questions, figured I'd pull an all for one deal. Apreciate any comments.
