All sound gone
Jglaser
So I have a pioneer avh x7500bt head unit one amp running my speakers and a 2400 watt amp running my two alpine swr12d4s and I'll be driving and out of nowhere all music cuts out I can play with the head unit for awhile to turn on the amps again so at first I though the rem cable but that's fine so I looked at my setup and when the amps cut out my 4 farad capacitor says low voltage so is it the capacitor or a bad connection to the battery
Only way to fix it. Remove the useless cap. Make 100% sure grounds are solid, All boost loudness boost EQ off, install big 3 upgrade(google it), set gain right(50% gain don't mean 50% power).
If you still have issues back the gain down till voltage is stable. If you do and its not loud enough for you look into a high output alternator.
Just got off the phone with Matt, that box isnt going to work, but ill put this out there..... https://www.soundoffaudio.com/ Anyone in south...
23
856
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
873
Marine speakers would be Ideal as stated and Coax. Polks would work very well. First choice of mine would be...
411
Jglaser
Jglaser
Pleasanton tx
fly_marlin
    May 16, 2024
    May 16, 2024
