all kinds of help needed
bsean63
Undead Revolution
ok i need all kinds of help... im going to buy a 0 gauge kit that comes with a battery terminal and fuse... the terminal is a cheaper one and the fuse is rated at 150A.. also im going to buy a distro. what size fuses should i use? and should i buy a better terminal?
if the distro will be close to the amps, you do not need a fused one:fyi:
i would fuse the wire anyways. what if it comes loose? i would do 150a inline for the monoblock, and maybe 80a for whatever smaller amp you get. i dunno if they make 80a anls though.
i have 2x 300a between batteries and 150a inline to both amps
i was told to have 150 inline and 2 300a in the distro??????
bsean63
Undead Revolution
bsean63
ohio
jco1385
michigan born
    May 14, 2026
michigan born
    May 14, 2026
