alarm turns on for no reason help?
monkeyman
hello guys i just got back from campin left on friday evening came back sunday as in today and well my alarm from my car was on neighbors came almost choked me said my alarm has been on all weekend i was like ouchhh so then right when i got here i turned it off and well i was in the RR and my alarm turned on again so i turned it off again and then i was outside looking at the car from my porch and the alarm turned on funny this is nothing is touching or hitting it but the wind and just now that im here it turned on again automatically for any reason is there something im able to do in that case becuase its driving me crazy it will turn on for any reason or no reason at all is there a fuse that is burned or something? please i need help ASAP b4 these neighbors put a 45 to my head //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
hard to say...
My alarm had an inertia switch on the fender under the hood. I couldn't tell you where yours is at.
Another alarm I had was a cheapy and it was on the back side of the alarm/horn unit itself.
I wish I could be more help but without being there, Its hard for me to pin point.
Did you get a manual with the alarm? If so, I would look through it or take it back to where you had it installed and let them adjust it.
well atleast your trying to help and i really appreciate it i guess i am gonna have to look around the car see if i can find a knob or button type thing or just end up taking it to get fixed //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif bummer
what kinda alarm?
If you have the alarm manual:
check this, next time the alarm goes off by itself disarm it, get in the car and look at the led (there should be an led light that blinks installed in the dash) and see how many times it flashes
most of the alarms iv installed, this flashing led is a code to tell you what tripped the alarm ie. door pin, hood pin, shock sensor etc.
the manual should tell you what the number of flashes means.
this is also depending on the alarm. which you did not tell us.
actually i know nothing about the alarm for the reason being that i bought the vehicle and it already had this alarm insalled and it didnt come with any type of manual or anything just with the little remotes for the alarm (used vehicle from private seller) so there for im not sure what to do.
monkeyman
monkeyman
los angeles,ca
Mustang01
michigan born
    May 14, 2026
michigan born
    May 14, 2026
