yeah i was looking at the second diagramThis is one way... I prefer to parallel the coils then series the subs personally... LOL!![]()
You golden now?yeah i was looking at the second diagramSubwoofer Wiring Diagrams, Two 2 ohm Dual Voice Coil (DVC) Speakers
same chamber is fine. I would rather gain match then strap. I was always louder gain matching then strapping. Along with many other people i know. Not to mention strapping places unnecessary stress on the slave amp. A few people that strapped tested their amps power after a few years and found the slave amp did significantly less power than the master amp. Not to mention strapping creates a sh*t ton of rise as well.So aero port? in the center? And what about dual chambered or same chamber?
Really?.. I've never read that anywhere till now... odd...same chamber is fine. I would rather gain match then strap. I was always louder gain matching then strapping. Along with many other people i know. Not to mention strapping places unnecessary stress on the slave amp. A few people that strapped tested their amps power after a few years and found the slave amp did significantly less power than the master amp. Not to mention strapping creates a sh*t ton of rise as well.
it was a big topic on FB. Sorry the traffic is all there nowadays.Really?.. I've never read that anywhere till now... odd...
I know it is... I'm still trying to get up to speed from the 90's... FB is a final frontier for me... LOL!.. I will not disagree but I haven't seen it yet...it was a big topic on FB. Sorry the traffic is all there nowadays.
Thanks for the response. Yeah I was planning on gain matching at first. You recommended just a middle slot port? Why? What about a kerfed slot port or middle aero port? And whats all this talk about people saying subs being fed by two amps should never be in same chamber?same chamber is fine. I would rather gain match then strap. I was always louder gain matching then strapping. Along with many other people i know. Not to mention strapping places unnecessary stress on the slave amp. A few people that strapped tested their amps power after a few years and found the slave amp did significantly less power than the master amp. Not to mention strapping creates a sh*t ton of rise as well.
middle aero is fine. Slot port is not optimal solely because one sub is closer to the mouth of the port than the other sub which will cause uneven pressure/loading aka when you see the subs playing out of rhythm of each other. As long as you gain match right, there is no issue.Thanks for the response. Yeah I was planning on gain matching at first. You recommended just a middle slot port? Why? What about a kerfed slot port or middle aero port? And whats all this talk about people saying subs being fed by two amps should never be in same chamber?
Okay cool man. Seriously thanks so much! Sorry this is my first big league system and I just want everything to go really perfect. Now when gain matching I need to match the subsonic filter and obvilously the gain. I was gonna use y splits from the headunit. What do I do regarding the crossover. Never done this before. I'm going to have my friend helping me who actually builds his own woofers from scratch but I want to learn this as well.middle aero is fine. Slot port is not optimal solely because one sub is closer to the mouth of the port than the other sub which will cause uneven pressure/loading aka when you see the subs playing out of rhythm of each other. As long as you gain match right, there is no issue.
I had my two 18s setup back then on two amps strapped, same chamber box. It was meh at best, generally weak for what the setup was. I took the amps out and gain matched it. WAY louder and better sounding.
That's good to know man, thanksmiddle aero is fine. Slot port is not optimal solely because one sub is closer to the mouth of the port than the other sub which will cause uneven pressure/loading aka when you see the subs playing out of rhythm of each other. As long as you gain match right, there is no issue.
I'd love to see the science behind this claim. I really don't think you understand how impedance works.strapping creates a sh*t ton of rise as well.
