Ahhhh!!! Help
danparkinson
Okay well first off i just bought a new head unit, its a jvc kd r600. I had replaced the jvc with a new jcv which is the kd r600 bc i thought that was the problem. I had got an amp from my buddy its a 580 dual amp 2 channel, I already had the sub. Its a sony xplod 800 watt 4 ohm, well after going to get all the wires and everything i then installed everything and after it pounded for a 10. When i first installed it my old jvc head unit was still in the car. It worked fine for about a month i would say, then i disconnected the amp and the sub because i had to put a lot of stuff in my trunk. After that day its never been right and for the last month i have been trying everything i know to get it back to working but nothings changed. When i hooked everything back up it worked but didn't hit hard at all, so i thought i maybe hooked a wire up wrong, but nothing was wrong ground was fine, rcas were fine, power was getting 12 v constant and remote was hooked up fine on head unit and amp. After looking at everything and not finding anything i said whatever. Well i let it go for about a week then i looked at everything again and i couldn't find anything!! it only got worse from there it went from not hitting hard to cutting in and out, to it cutting out my speakers. SO after everything i said fu** it and went and bought a brand new 115$ jvc head unit. After installing everything i hooked the remote up etc. The **** thing is still doing it!! I have tried 2 other amps and 2 other subs and its doing the same thing. Im ready to just sell them but i don't want to. I am completely out of ideas... Please HELP
i said "ahhhh real monsters!!!!".
Didn't see that one coming. Seriously funny. Lmao.
As far as the problems go, and take this with a grain of salt as I'm still new to this game, it almost sounds like a dirty connection or something faulty within the amplifier. I would disconnect, clean, check and recheck all of the connections and see if that helps at all. It can be a tedious task, but it never hurts.
danparkinson
danparkinson
Pittsburgh, PA
>>SQL<<
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
