Aftermarket antenna install (BAWM200)
As long as the antenna doesn't draw to much current. I would think there would be a fuse inline with the power wire on it that should give you some insight into its consumption. If it is higher than 10a, I would find a different source
I received my BAWM200 today and the ground cable is less than a foot long. I'm not sure where to ground it. If I install mine on my upper front windshield, where should I ground it?
Ok I extended the ground wire, installed everything, butt-connected the red 12v wire from the antenna to the red 12v wire on the stereos wiring harness...now my radio doesn't come on at all. Then I reconnected the stereo's red wire to the red wire on the wiring harness adapter and the stereo comes on perfectly (still using old antenna with bad reception). Am I doing something wrong here? Someone suggested connecting the red wire from the antenna to the blue/white wire on the stereo's wiring harness because its for those powered antennas that automatically rise and fall when the car is turned on/off...is that a good or bad idea?
Is there any chance that the radio may output too much power thru the blue/white wire and cause some kind of epic destruction of the antenna?
It shouldn't hurt anything. It's the same thing as a power ant lead. Besides, it should have a built in voltage thing(durr). lol
Look on the back of the ant or in the manual. It should list it's power consumption as amp's (a) or milliamp's (ma) with a # before it.
Of course there is no manual and the box doesn't say anything about amps or milliamps. There is a website listed. I went there and found an email to tech support. Emailed them. Will update the post when they respond.
shilent
shilent
East Bay, CA
bodowd
