aero ports
Dozy_production
Poel
Excuse my french but im a little distraught after watching a good hour on anti scientologist docuementaries.
So i have searched and use a couple of the calculators determining the relation to aero port length to its diameter. So the smaller the diameter the shorter the length is needed to achieve the same tuning? So what is up with people recommending a 4 or 6" diameter for one 12" when a 4" aero port (according to these calculators) can be used with the length of roughly 7.5 inches. i mean a 6" would mean the port to be 17 inches!
I want to get a 2.5 ft^3 tuned to 38 with a 12" hd3. Fyi.
Its the same principle as slot ports. With less port area, you decrease your port length but with too little port area, you can cause port noise. Aeros are more efficient so you can get away with using less port area than their slotted counter-parts and the flares on both ends reduce turbulence. If you were in the chat earlier you would have gotten a nice lesson about aeros...
I'm no expert but for 2.5ft^3, I'd do 2x 4" Aeros
if your putting a HD3 in a 2.5cuft box you want 4 x 4" ports or 2 x 6" according to audioque //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
they want 40sqin of port area for a 2.5cubed box. and mind you this is after displacement to figure a larger box to get the 2.5 after sub and port displacement.
thanks for the input. Im still confused a little though so patience with me on this one. Okay so if i would go for 2 6" how long would they need to be? Pretty short? Couldnt i go with just one long 4" or 2 longer?
How does the length play into this is what im trying to say. If you any of you have a nice informative site you can post a link instead of explaining if you deem it neccessary.
no im not a scientologist. i posted that video thread.
There is nothing weird about that at all. The more round ports you add, the more port area. The more port area, the longer the length to achieve the same tuning.
The more port area, the lower the turbulence of air in the port. That's why people don't use smaller ports even though they will be shorter.
4" areo is roughly 12.56 sq.in. not including the flare. (pie)*(raidus)^2=area of circle.
3 4" will give you ~38 sq. in. of port. Remember 12-15sq.in. per cubic foot is a good number for daily and 15-20sq.in. for SPL applications.
So...2.5 net @ 38hz with 3 4" areos would be each port being 26.22" long.
Dozy_production
Poel
Dozy_production
San Diego, CA
Dozy_production
