aero ports, help please?
EricBrantley
New to this site, wanting to build my first aero ported box, but still dont quite understand the concept. Ive read and read, but some of it just still isn't sinking in. Can someone maybe dumb it down for me a bit? Dont know how to figure out how much port is needed for however big box and such. I wanna COMPLETELY understand everything before i try to build, or pass my knowledge on to others..
Thanks,
Eric
We all basically go by rules of thumb. I like to be able to run the most port area that I can fit. The more port area that you have the longer your ports have to be, so there is a limit as to how much port area you can have. Play with the port calcuator on psp-inc.com and you'll get a better feel for this.
okay.. but how do i figure out how much port area that i have to have? then how do i use that information to figure out how many ports are needed and how big they have to be and such?
if you are THIS not sure, do not , I repeat , do not attempt to pass on any thing to anyone!! (hell don't even reproduce )
nah!! j/king rule of thumb fpr slot ports is 12-16 in^2 per ft^3 aero's 8-14in ^2 per ft^3 opinions will vary on this subject
but there is a base to build on
i've built w / more port area than that w success on some times not
also used less w/success and not so just keep that in mind and dont force your self to use 16 when 14 will do nicely
You develop a feel for that as you gain experience with enclosure theory. If you plan on building an aero box then there are people on here who can help you figure out what you need.
ok cool.. i appreciate the help, i just dont wanna do this wrong when i do it.. it so much easier to consruct one and put it together than a slo ported box, but soo much harder to figure out for me..
i went to that calculator thing and typed in 2.3ft^3, 38hz, 4" port diamater, and 2 ports.. it gave me 18.47. is that how long each port has to be? or is that combined, the 2 ports have to be 18.47 inches long?
1 AQ hdc3 12.. i dont think the one 4 will fit in my box though.. what would be some alternative sizes that wouldnt be as long but give me the right port area?
scratch that..... idk why i said 1 4 wouldnt fit, i was still thinking of it being too little port area. the 1 4" would fit, just trying to figure out what would be best..
what do you mean by 'they wont fit'?
you can always use elbows to turn the port if its longer than your box is deep...
EricBrantley
EricBrantley
Waycross, Ga.
perfecxionX
