Advice on....well, everything ; )
Stormj
Hello, first time poster long time reader. I am looking for answers, opinions, and thoughts on what I should do for a speaker install. Back ground, I have a 2000 Ford F250 Supercab. Diesel, so it makes a lot of noise. It is a work truck, as much as I would love to do something like the beautiful photos I see you all post, my truck get muddy and wet from the floor six inches up. I have a Jensen VM9413 head unit installed and factory speakers. Supposedly it puts out 13w rms, 40 peak. I would like to upgrade the speakers, I listen to a lot of classical, blues, jazz. I was looking at the Infinity Reference 6820cs componet system because from what I read componets have a much better sound. I am assuming though that the head unit will not run componets? I am looking for ideas on where to stash a suitable amp. Look forward to everyones replies and suggestions.
Thank you,
Storm Johnson
I think the Infinity Reference is a decent choice, I like them much more than the Kappa line (despite being more money).
Like these:
Infinity Reference 6830cs 6"x8"/5"x7" component speaker system at Crutchfield.com
You'll certainly be happier with them on a small amp. Mounting on the back wall may be an option if you cant locate it in a dry place under the rear seat.
Infinity Reference 475a 4-channel car amplifier 75 watts RMS x 4 at Crutchfield.com
A 4-channel amp is more flexible - you may want fronts and rears, you may want fronts and a small sub.
If you take some pics of the inside storage areas you are willing to consider, we can comment on them. But you'll need to take the amp choice into consideration.
i really liked the infinity kappa perfects i heard...i think youd like them...it would be a huge change from your stocks speakers. also a nice 2ch amp would be great! like 100x2 @ 4ohms would be ideal
I like your idea of placing the amp on the back wall Rich. The back seat is usually in the raised position for storage of work related materials. On an extended cab pick up the back of the rear seat mounts directly to the rear wall, so there would not be a lot of air flow, would this be okay? I am looking at replacing both the fronts and rears, would a 4 channel be best or two 2 channels? Do I run, audio out, wiring from the amp back to the head unit area to tap into factory wiring or is it best to run new wires from the amp to the new speakers? Suggestions on amps?
Thank you all again,
Storm J
I very much like infinity components for low power applications and their amps/speakers can be had for short money from the JBL/Infinity/harmon ebay store as refurbs.
That Jensen HU is pretty nice, I used one for a while and although I never use the speaker-level outputs I really like the screen resolution, features, and the fact that it does 5.1 surround (something to work on LOL). I don't think ANY head unit does more than 13-15W output continuous to speaker channels regardless of what they claim. An amp will be a HUGE upgrade once you install some proper speakers.
I'd DEFINITELY look into a 4 channel or two small 2 channels. Those Jensen head units will down-mix the center channel (make sure you set it up with the center and sub off or your movies will sound like ***). Surround effects in movies are totally worth separate channels for the front and rears!
If you want specific amp suggestions you should come up with precise size limitations and a budget you'll get plenty of help here.
You can run a single umbilical from the HU to the amps containing all 4 speaker outs, your RCA cables, and remote turn-on then simply connect the speaker outs from the amp up behind the dash. Ideally you could run new wire from amps to speakers but often it's more pain in the arse than it's worth, particularly if you're just dropping simple components into factory locations. The factory wire is usually pretty shabby, but for low power and short runs you'd likely not notice the difference.
Be sure to tape up the speaker outs from the HU after you disconnect them since a short would probably smoke your HU
Thanks Hispls, love the sheep pic I lmao. As for amp size, if I mount it behind the rear seat back cushion, I see no restrictions other than about a 4" depth limit. Length and width are no problems there is a lot of area back there. Price....I gueess I would like to keep it to $400 for amp(s) if possible but I am a bit flexible if those in the know suggest better. I guess a good gudieline would be the speakers, they are a costing me $109 per pair, what would be a comparable value. I dont want to ruin anythign by putting in crap but I do not need to over power them I would think. I do not think I need a sub for my listening style, I assume the speakers can handle it. Not my area of expertise so I default to my betters.
No mclerco83, I was not intedning on bass. I was thinking with the style of music I listen to in the vehicle that a sub would probably be over kill.
a sub is never overkill. you dont have to rattle your glass with a sub. just use it to take the strain off your small speakers so they can play louder and much cleaner.
yea speakers can onl play so low usually dont want to go under 80hz and the sub will make a hug difference as a total listening experience the subs i mentioned do not get loud or something like a boston g3
Stormj
Stormj
East Coast
misfit138
