Advice on switching over to Sundown.
alxben95
So in my current crap setup i have 2 12inch re rex subwoofers. Don't bash too hard, it was my first experience with subwoofers, and i just wanted to see if i would like it. But now i've been bitten by the bass bug and I can't get enough. So my question is do you think that 1 sundown sa 12 would have more bass output that the 2 crap subs i have now? I'll be powering it with the 1000W re amp i have now that says it can do 800W at 1 ohm but i doubt that.
The REX woofers arent horrible.. RE makes good stuff, what are the specs on your enclosure? You will losing cone area 1 12 vs 2 12's the 2 will usually win especially on the same amount of power.
yup get a box made up and try that. there is a couple box builders and designers here so it shouldnt be a problem for to find one.
Okay guys thanks for the advice. I wouldn't mind building it all myself, but what specs should i build it to? One day i would like to upgrade the subs too, so wouldn't that be bad to design the box specifically to the re subs?
@double 07 ; there ya go
Matt
edit: also you could have a box built for the subs you intend to get and just throw the RE's in it. as long as the required enclosure isnt too far off they will sound good and sound a hell of alot better than the prefab.
Building your own enclosure is the cheapest and most rewarding way. You can purchase a design from one of many sources and use that to build an enclosure.
Altering your subs may indeed change the enclosure required to get the fullest potential from them.
alxben95
alxben95
Houma, la
its10v1
