Hi,
I would like to get some insight on how to pick the best Subwoofer for my setup which consists of the following:
GM-D9604 Pioneer Amplifier "Link"
Pioneer TS-A6995R 6x9 speakers "Link"
I have also bought a dual amp wiring kit from Rockford Fosgate which allows me to add another amp if needed (0 gauge), my vision is to have the setup done with a 3x channel, 2 of them running the 6x9 and a single subwoofer, and if the sound doesn't suites me I may add 2x6.5" to the front doors and add a small amp to feed it or hook the main amp as 4 channel and buy a mono amp for a sub.
question is: which Sub should I go for to get maximum benefit? do I go for a dual 4 ohm or single 4ohm? how much power will my 3rd channel will be able to dash out (RMS)?
I've googled for an answer but the dual coil / single coil part confuses me.
please help
Speakers specs:
Size 6" x 9"
Max. Music Power (Nominal) 600 W (100 W)
Cone Material Multilayer Mica Matrix Cone
Frequency Response 27 Hz to 37 kHz
Sensitivity (1 W/1 m) 92 dB
Impedance 4 Ω
Crossover Frequency ―
Mounting Depth 3-3/8"
Cut-Out Dimensions 6" x 8-5/8"
Amp Specs:
Maximum Output Power 4 x 260 W (4Ω)
4 x 400 W (2Ω)
2 x 800 W (4Ω bridged)
CEA 2006 Power (THD + N = 1%) 4 x 130 W (10 Hz - 50 kHz / 4Ω)
2 x 400 W (1 kHz / 4Ω bridged)
4 x 200 W (1 kHz / 2Ω)
75 dBA (ref: 1 W into 4Ω)
Continuous power output (RMS)4 x 100 W (20 Hz - 20 kHz)
4 x 150 W (1 kHz / 2Ω)
4 x 125 W (1 kHz / 1Ω)
2 x 300 W (1 kHz / 4Ω bridge)
2 x 250 W (1 kHz / 2Ω bridge)
Frequency response10 - 50000 Hz
Distortion
S/N ratio> 95 dB
LPF40 - 500 Hz (-12 dB/oct)
HPF40 - 500 Hz (-12 dB/oct)
Size 6" x 9"
Impedance 4 Ω
Amp Specs:
4 x 400 W (2Ω)
Distortion
S/N ratio> 95 dB
please help
