Advice on Kicker zx1500.1
im running an hdc315 on a kicker zx1500 and i want to put it in a 4.2 cubic box.. what should i tune it to? and should i run it at 1 ohm? 2 ohms? zero gage wiring? additional info is in my sig
use 0 guage wiring and run the amp at 2 ohms. Since you have a upgraded alt you could probably run it at 1 ohm, but its not covered under the warranty at 1 ohm. i myself would probably run it at 1 ohm but thats because my friends have before with no problems. The amp puts out plenty of power at 2 ohms so either way you should be fine. From what i hear the hdc315's like higher tuning, so somewhere in the range of 36-40hz should be good.
edit: well seeing how you have the dual 1 ohm sub, 2 ohm to the amp is your only option. So wire the subs in series to get 2 ohms and you should be fine. Let us know how the hdc315 does off that amp, apparently some guys are saying minimum 2500 rms for that sub.
x2
should i just get the zx2500 then? cuz i can afford that 1 too im just scared itll be too much power.. and if u do recomend the 2500 wat should i run everything at in that case...
yeah at least 0 gage wire and lots of good grounds "big 3" also id run that amp at 1 ohm.. once you take impedence rise and voltage drop into account at 2 ohm youll prolly be rising to 3 ohm and not getting much power out of you amp.. so id get a dual 1 sub and wire to 2..
SlapinTheTrunk
SlapinTheTrunk
Los Angeles
blackbonnie
