The standard recommendation for rear speakers is that they should be playing attenuated most of the time in order not to confuse the sound stage. Therefore they don't need to be as good as the front ones. A more convoluted recommendation states is that they should be bandpassed and time delayed by about 20ms if you have this capability, to be mostly for ambiance sound effect. In either case, there is no need for a strong amplifier or top of line speakers to go in the rear.
If you want to use rear speakers as midbass, this conflicts with the goal of not confusing the sound stage. If you do need that midbass capability, I would have used 6x9 speakers and bandpassed them. Since most stereos and amplifiers do not have low pass capability that works for midbass, I'd insert an inductor into the speaker wire circuit with a value corresponding to 6dB low pass filter at around 200Hz. One really good 6x9 speaker is Hybrid Audio Imagine component set, the 6x9 version. It's actually kind of waste to use them as midbass only because a great overall set of speakers to run active, that happen to have very good midbass. I have 6.5 version running active in fully sound proofed doors and it feels like I have all midbass I could ask for.
