Advantages of external amplifiers?
Receivers have more 'stuff' inside the chassis that takes away real estate from the
internal amplifier 'section', so for the same chassis size, an external amplifier has the potential to
have more room for 'guts' to make the amplifier more robust. It all comes down to how
the product is engineered. Some brands of receivers actually make discrete amplifier design
instead of placing 'chipamps' like those found in HU's. The chipamp product is usually the
low end brands. Even the discrete designs aren't 'over-engineered' like an external amplifier can be due to the space restriction.
Because you have a real estate issue, that doesn't mean you can't engineer a solution
to the problem. Look here;
http://usa.denon.com/ProductDetails/226.asp
This is the big Denon reciever. 10 channel, 170w channel. For $6K msrp, I'd
rather buy a $500 receiver and use the leftover $5500 to buy external amplifiers because
that kind of cash would allow me to get more power than what the Denon offers, but
I would have a rack of five 2 channel amplifiers though. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The only way to now if the reciever meets spec is to measure it.
I'd imagine that every product would be different.
Since most people can't or won't measure products, a good
alternative is to choose certain brands that have a good reputation. H/K is good and
their specs probably can be trusted.. so look at the specs to see if it meets your requirement.
Most if not all reciever are not 2 ohm/ch rated so if you plan to use it as such you might have issues.
[some may be rated for as low as 4 Ohm/ch, usually 6-8 Ohm is common.]
btnhfan
Hail to the King Baby!!!!
btnhfan
CT/ GA Tech, Atlanta
thylantyr
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
