Adding speakers to a 2 speaker system
  • Thread starter Unregistered
  • Live activity
  • Replies 1
  • Views 1K
U
Unregistered
Guest
Forgive me, I know this is a speakers 101 question, but it's been a long time.
I would like to add two 6 x 9 speakers to a factory radio that supports only two speakers. The connector on the back of the radio is wired as such:
Yellow - +12V Memory
Red - +12V
White/Orange - Dimmer
Orange - Illumination
Black/Grey - Right Front Speaker
Black/White - Left Front Speaker
Blue - Ground
Is it reasonable to splice into the speaker connections and both to the ground?
Thanks.
NO. Never use ground for a speaker return lead. If your stereo can handle additional speakers, you would connect them to the same pairs of wires used for the existing ones.
You may find that your factory stereo won't handle additional speakers without becomming distorted. The best solution is to use an external amplifier for the new speakers and tap into the existing speaker wires for the amp's inputs. That'd also give you the ability to adjust the balance front-rear.
Guest
maylar
firey_kimchi
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
