Adding Second Amp. Need Help Choosing Wiring.
  • 6
ekmgray
Hey guys, I drive a 2001 Dodge Durango. I currently have an Alpine Mono Amp thats running at 500w RMS at 2 Ohms, through a 4 Gauge Power Wire, Powering an Alpine Type R. I would like to add a Pioneer gm-d8604 Amplifier, which runs 100w x 4 RMS at 4 ohms, for my four Alpine Type R 60-c door speakers.
I would like to know if I can run my 4 gauge power wire to a distribution block (should it be a fused one?), and have two 8 gauge power wires running from the d-block to the separate amplifiers. Or is it too much power for those size wires?
Also, should i upgrade my stock speaker wires? to what gauge?
Yeah man its not too good of a idea let me get you the link to some cheap 4 gauge I just saw... best to do another run of 4 gauge or run one 0 gauge into a distro and 2 4 gauge outs...
its a little sketchy if u run the 4 gauge from the battery to the block. i would upgrade it to 2 or even 0 gauge. then u can run 2 4 gauges out of the block to the amps
A single 4 gage split into two with a distroblock would be fine for those 2 amps. The 4 channel will average much lower than 100 per channel, you could even get away with 8 gage for that.
BTW each 3 wire gage steps is a X2 in cross section, which means a 4 gage is equivalent to two 7 gage wires. More than enough for 2 amps that want 8 gage.
@maylar
Just to be clear.
Battery---> 4gauge input with 100amp fuse ----> distro block -----> two 4 gauge output (no fuses) ------> amps
put a ; behind @Maylar no spaces.
And yes. make sure your distribution block had the right fuse. Check your amps manual
977
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
807
Thanks. That makes sense. It sounds pretty good as is.
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
ekmgray
ekmgray
Los Angeles
calebkhill
