Adding Second Amp. Need Help Choosing Wiring.
ekmgray
Hey guys, I drive a 2001 Dodge Durango. I currently have an Alpine Mono Amp thats running at 500w RMS at 2 Ohms, through a 4 Gauge Power Wire, Powering an Alpine Type R. I would like to add a Pioneer gm-d8604 Amplifier, which runs 100w x 4 RMS at 4 ohms, for my four Alpine Type R 60-c door speakers.
I would like to know if I can run my 4 gauge power wire to a distribution block (should it be a fused one?), and have two 8 gauge power wires running from the d-block to the separate amplifiers. Or is it too much power for those size wires?
Also, should i upgrade my stock speaker wires? to what gauge?
Yeah man its not too good of a idea let me get you the link to some cheap 4 gauge I just saw... best to do another run of 4 gauge or run one 0 gauge into a distro and 2 4 gauge outs...
its a little sketchy if u run the 4 gauge from the battery to the block. i would upgrade it to 2 or even 0 gauge. then u can run 2 4 gauges out of the block to the amps
A single 4 gage split into two with a distroblock would be fine for those 2 amps. The 4 channel will average much lower than 100 per channel, you could even get away with 8 gage for that.
BTW each 3 wire gage steps is a X2 in cross section, which means a 4 gage is equivalent to two 7 gage wires. More than enough for 2 amps that want 8 gage.
ekmgray
ekmgray
Los Angeles
calebkhill
Giles
    Jun 27, 2026
Giles
    Jun 27, 2026
