adding a second battery
with that do i need to ad an inline fuse from the front to the back. and can i use any battery or does it really have to be bry cell
That sketch misses one VERY important thing. Inline fuse, within 18inches of the front battery...I'd go with something like 200-300 amp ANL fuse.
NG
And you need two inline fuses to correctly/safely wire that. Think about it - battery in the rear has power, battery under the hood has power. a single fuse under the hood?? still leaves you with power on BOTH side of the wire. See below
Wrong - (+) on both sides if fuse blows
----F.Battery +++Fuse+++++++++++++++++++++Rear Battery -----
Right-
----F. Battery +++Fuse+++++++++++++++++++++Fuse+++R. Battery----
So when a the fuses blow:
----F. Battery +++( )xxxxxxxxxxxxxxxxxxxxxxxxxx( )+++R. Battery----
and PLEASE only use a sealed battery in the rear. I have gotten sick from battery fumes, it is not pleasant.
bigv123
bigv123
chicago
hcoronado
