add another sub or stick with what i got?
lexus rx
love tha bass
i have been running a mmats 1400.1 to one eclipse titanium 15 for about 2 months now and i havent had any problems SO FAR. i talked to david(v.p.) at mmats friday and he told me that i would melt the voice coil in my speaker if i continued to run the mmats to just one speaker. should i get another ti-15 to be on the safe side or will i be allright? thanks
hmm, how mcuh power r u runin to the eclipse? (at what impedannce is it i guess)
i dont know if that would actually happen to tell u the truth. but anyways, one sub is fine, unless u want louder, n that amp can push 2 15s w/o any problem then go for it.
i'm running the speaker at 2 ohms. david told me the amp can push around 1600-1700 watts. but that is at 1 ohm. i dont know what it is doing at 2 ohms.
If your running it at 2 ohms and you buy another speaker and knock it down to 1 ohm then you will basically be running the same amount of power per sub that you were to begin with. You are probably running around 600 - 800 to your speaker right now. But buying a speaker like he want's you to won't make the power handling any better. But buying a second speaker would increase your volume by double, or around double.
right now i have all of my audio stuff in my civic. i am in the process of getting all of my wiring problems fixed in the lex. LEXUS **** FAT ***KING NUTZ WHEN IT COMES TO ADDING AFTERMARKET STEREO EQUIPMENT. sorry, i had to get that off my chest. dave gave me the number for a stereo shop that sells mmats and eclipse to call. when i talked to the owner he told me that he has melted 4 ti-15's(run to one speaker at a time) with the mmats 1400.1. so i guess two would be best. if it goes in the civic with the other one then i am worried about blowing out some windows. or shaking my teeth out of my head,whichever comes first. im going to experiment a little with different subs(ordered a 15xxx but wont be available until 1st of jan.) see how that works. im going to get another mmats(2200 or 1400) caude the dealer i got mine from has the bomb *** deals(1400 retails for 899?, try **** close to half that through him). one more thing, if anyone has some info on some secret way to wire up a lexus rx 300 PLEASE hit me up. right now i am running new wiring to every speaker so i can install an alpine hu. cant take out the stock one without major problems and major wire cutting.
lexus rx
love tha bass
lexus rx
north cakalak
lexus rx
michigan born
    May 14, 2026
michigan born
    May 14, 2026
