Acura/honda volt regulator?
ya i dunno whats up. I got an acura legend (very similar to vigor) and i get a 14.2 reading with the car at idle...stock alt and a kinetik in back
hmmm.... Legend and vigor are **** near same. hmmm..??? i will try and replace my battery and see if that helps? in your Legend you have a 110 alt too right?
whats the voltage at the battery? Does it chang when the cars on/off? I just changed the voltage regulater in my van. Problem is they are now incoporated into the ECU. So if its the reg, you may need a new ECU.
BTW, Mine was $700 at dealer just for the PC. They can be had cheaper online, but it has to match exactly.
eh... i hope not, this car is a 1992... Yes if i remember right the voltage dropped when the car was off...around 12ish i think. anyone else have this experience with a honda? i read someones crx had a built in one a while ago, might have another model but it was a honda
you can allways take it to autozone and they do a load test on ur chargeing system...
you are gunna need to talk to a honda/acura dealership to see what is involved as far as the voltage regulator being in the alt, or the ECM...
Joseph M
149.00 db club.
Joseph M
Moxee, Wa
edzy
