Actuator Advice
  • 5
actuators can push much more than that.
As for 4", I guess it would depend on where you install the actuator. If it's with a pivot, you sould not need that much. Good luck workig with hydraulics~
I am finally ready to do this... 3 years later... same box. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You can take a look at my box from my Gallery link. I have no idea where to start with this though... I've found actuators that have 4" and 6" strokes with built-in limit switches.... any suggestions?
Are you talking about using motorized linear actuators? or hydraulics?
Its kinda hard to give advice since I cant see the setup. It'll just take some customizing.
Only thing I can suggest is to definitly go with the linear actuators.
I've done some calculations and I need about a 6" throw. So, if I purchase a 12", I can use the built in limit switch to cut it off at 6", correct? The 12" is the same price as the 6" so I might as well get that one...
I also want to be able to just hit a button once (not hold it) and have it open/close (or up/down). What kind of rocker is needed to accomplish that?
Since that actuator uses a mounting bracket with a quick release pin, how have others solved the problem with it rattling with the bass? I can just see/hear it now... that pin would drive me nuts.
Last question... I would like the neons inside the amp rack to come on at the same time I hit the button for the actuator to open the lid. How would I do that?
for the bass, I've used plasti-dip applied with a brush to either piece I didn't want rattling.
post what you find out about the N/O or N/C circuits.
Thanks. I think I've figured everything out but this:
what did you come up with so far as far as controlling the actuator? maybe you can include it in there somewhere.
You could do it with a latching relay, turns on once you hit the open switch, and shuts off when you hit the close switch.
Hmm...I dunno if that switch will do it. It says it operates like a power window switch, so I think you'll have to hold the button.
Also, it says that the limit switches arent movable, so that might make it difficult to cut it off at 6".
How many wires are coming out of the actuator?
Their sales person said the switch will stay in the position until it reaches it limit so you do not have to hold it down.
I don't know what you mean by the limit switches... I just assumed they make it the actuator brake. No?
There is just a black and red wire from the actuator.
579
It also lowers the amps efficiency and raises the current draw.
712
882
I always leave approx 6" or so for that very reason, in case I decide to swapp an amp if needed,or wanting too.RCAs ect. I deff do the extra 6-8"...
955
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
SirSteve
SirSteve
USA
SirSteve
