Active crossover?
Absolutely will..SStream make pretty decent stuff also.
So i ordered that db drive e7eq nd my 4 channel amp is still only playin low notes i disconnected my sub amp nd put my 4 channel on those wires with my 4 pa dbs70 6x8s still no high or mid jus lows someone help ive adjusted everything could this be the amp
No, you've probably got a low pass filter turned on on your head unit
I have rewired it my sub is playin good but i have same problem i cant find out what i need to change im only getting low notes on my 4 channel
Double check all the settings on your head unit, like I said you probably have a low pass filter turned off which cuts out all the high frequencies from going to the sub, but you don't want that on in your case.
So wat if i have a hu with 2 sets rca in the back,front nd rear, could i use a rca y for my 4 channel amp running from front nd my sub from rear
Run your four channel from one set of rca's with a y splitter at the xover just be sure u put one set on left speakers and one set on right speakers and run another set of RCA's from deck to sub input on xover
john_doe_318
john_doe_318
bossier city
SounDrive
