jmanpc
CA.com Nostalgist.
You totally missed my first point. I said that its cool that the sub can handle 1000w thermally, but it doesn't mean shit if it can't handle it mechanically.Thus you fail to comprehend the difference between thermal power handling and mechanical power handling, and the factors that can affect the mechanical power handling.
See above.
Also, I guess I fail to see the fault in the design for failing when overdriven by 60%
Sag is pretty common knowledge in most other communities when mounting the driver horizontally.
Adire used to have a white paper about it on their website, and explained formulas for calculating which drivers (based on specs) should probably avoid being up/down fired.
I guess it's more laughable you were not aware of this //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Then I guess you aren't very good at abuse //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
It's not difficult to exceed the mechanical limits of a driver.
You're inability to comprehend much of the information present in this thread is what's laughable.
Again, I will repeat that this woofer really isn't suited for car audio use, and I don't understand why it's being marketed as such. Why?
Car audio subs are generally more likely to be abused. If a kid is given a 1000w sub and a 1000w amp, there's a good chance that he'll clip the shit out of the amp to make the sub louder. On top of that, if music with gratuitous amounts of bass is played at high volume, that is torturous to a sub's suspension.
I see the AV as being a home sub primarily- from what I've read, it has soft suspension and doesn't fare well under continuous beating. Like I said, a movie filled with explosions and other bass-intensive scenes won't abuse a sub as badly as the entirety of a rap album. Why? Because in movies, intense bass is short-lived and sparse. On top of that, people tend not to keep their HT setups ridiculously loud because of neighnors.
Anyone who wants to put a sub on the shelf for the car audio market needs to understand that their woofers will be abused. If your sub can't withstand abuse for even a couple days, you're going to see a very high failure rate.
