? about mounting depth
ARK_SWAMP_RIDER
Arkansas
I'm looking at a JL 8w3v3, which has 4 9/16 md. My box has 4 1/2 md. 1/16 isnt a big difference. It is a sealed enclosure, with the correct internal volume. Will I be able to use the sub in my box, or will I have to have a new one? Any way to gain 1/16? Thanks.
Also you can sand out a small spot on the back wall of the box if you need a little more room, such as an angled truck box and the corner of the magnet barely hits.
I know it is 1/16 to big for my box. I am not sure if that is a conservative measurement on the sub. I thought about sanding, because if the sub will fit, everything else is perfect. Any more thoughts/opinions? Thanks.
Everything is correct as far as internal volume. I'm confident that if it fits the enclosure, it will sound great, couldn't build a better enclosure (assuming it will fit, if not, back to square one). Thanks.
Just add a spacer ring to the front of the box to push the sub out 3/4".
*note*
If there is a pole vent this will not work and you would need to add about 1.5" to the front of the box.
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
352
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
6K
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
ARK_SWAMP_RIDER
ARK_SWAMP_RIDER
Arkansas
SPY
SPLBassJunkie
    May 21, 2024
    May 20, 2024
