AB 175.1 FOR TC based sub & amp
k3n12ock
WTT: AB 175.1
Features/Specs
I OHM STABLE D CLASS MONO BLOCK AMPLIFIER
LOW LEVEL INPUT AND OUTPUT
FREQUENCY RESPONSE: 20Hz~350Hz
INPUT LEVEL: 0.2V~6V
VARIABLE SUBSONIC: 10Hz~50Hz AT 24dB/OCT
VARIABLE LOW PASS FILTER: 35Hz~250Hz AT 24dB/OCT
VARIABLE BASS BOOST: 0~9dB AT 45Hz
REMOTE GAIN CONTROLLER
TWO AMPLIFIERS LINKABLE CONNECTOR AND SELECTOR
FUSE RATING-250AMPS, LINKED FUSE RATE: 500 AMPS
EXTERNAL FUSE
WORKING BATTERY VOLTAGE:9V~16V
MINIMUM IMPEDANCE: SINGLE VFL-175.1 ; 1 OHM
LINKED: VFL-175.1 : 2 OHM
3300 WATTS
10/10 mechanical
8.5/10 cosmetic
Looking for a TC Based 10/12 and an amp to power it (Saz1500?)
I really love the baskets on them.
OR
Looking for a 10/12 that will do good in a sealed or even small vented application (2cu or under). Not too crazy about SPL any more since I have limited space so I'm looking to go more in sq/sql setup.
Trying to go SQ or close to it. Will trade for some decent sq/sql type stuff. Preferably some amps I guess. I have an MB quart discus 500.1 amp and sa8 motors/baskets to trade. Doesn't have to be top of the line sq but some mid level stuff that will have better sq than what I have right now.
sub amp & mids/highs amp. Rca's. All that good stuff. Would rather do some kind of package than splitting. OR someone buy this **** amp so I can but some sq stuff!!!!!!!
Will also trade for a mono amp & matching 4 channel (Saz 1500 & 100.4????) can add cash and/or 3 sa8 motors/baskets.
Really looking for some SQ stuff (sub & mids/highs amps)
k3n12ock
k3n12ock
MD/CNY
k3n12ock
